1 members (Rich'sToys), 90 guests, and 2 robots.
Topics128,079
Posts1,056,310
Members48,442
#1072906 12/12/2014 3:53 AM
hi all I am seeking clutch size for a 265v8 all the books from truckshop LMC don't have size for 265 v8 merry xmas to all
According to the Shop Manual, it is 10" for 1/2 through 1 1/2 ton for both 6 and V8.
Bill Burmeister
TPR57C #1073044 12/12/2014 10:37 PM
Riding in the Passing Lane
There were lots of options on clutch sizes. You have to measure it to be sure.
1972 Chevy c10 Cheyenne Super
Interesting read, might give you some idea of which clutch you can use:
http://www.hemmings.com/hmn/stories/2011/10/01/hmn_feature29.html
DG
Denny G
Sandwich, IL
I recently replaced a clutch on what appears to be an original 55-2 with a V-8. It was an 11" unit. I wouldn't buy any parts until I removed it to be sure.
Fred
I also have a 265 and it depends if it is a truck or a car motor the flywheel is different sizes found out mine is out of a Belair and it is smaller then a truck
TPR57C
I have had a few '57 3100's with 265/4 speeds, all are org and all had 11" clutchs. For what it's worth.
delky dave in WYO
1957, 3100, v8
2016 gmc 4wd
delky #1080756 01/22/2015 11:36 AM
Finally pulled clutch out 11 inch 10 spline worn out that much springs on clutch plate were rubbing on flywheel bolts
