| | | Forums66 Topics128,035 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Would anyone know what color code#531 is,my 55 Canadian GMC 500 series LCF has this code.there is about 7 layers of different colors,would like to go back to original. Serial#is 5033095202 if this helps. Thanks Biddaboy
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Bid: where are you pulling the information "Paint Code 531" from?
You serial number seems incomplete. Is your truck of Candian production? It should start with a 9 instead of a 5.
Does the ID plate say Ottowa or Pontiac? | | | | | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Hello OCK the numbers are off the VIN plate on door pillar I have a picture of the plate in my photo album at http://photo.starblvd.net/gumby13 have alook Biddaboy its on page 1
