1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | Does anyone recognize the lug nuts/studs in this photo. These are different than the ones on the front of my truck. These are the rear wheel dually. Why do they have the square shape at the end of the stud? I am having trouble getting the lug nuts free. This frame has been sitting outside for a couple of decades. Any tips/info/advice? Lug Nuts | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy LewyBoys, those are standard Budd wheel inner and outer nuts, the hex nut holds the outer wheel on, the nut with the square head holds the inner wheel on. Sometimes the inner and outer nuts seize together, this can happen if the inner nuts were not tightened correctly. On the left hand side of the vehicle the nuts are left hand thread, on the right side of the vehicle the nuts are right hand thread, there should be an identifying "L" or "R" in the center of the square nut, hope that helps. | | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | Thank you both for your help. I will give it some heat this weekend and try to get them loose. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hey LewyBoys! 3B and crenwelge know their stuff. The '59 Viking bus has the same style rims.We soaked all the nuts with WD40,and PB blaster for about a week. Then we had to heat the nuts,and we used a "breaker bar",with a 4'pipe,to finally get them to break loose. Take your time with them,so you don't break a stud. Hope you can find some 22.5's,and get away from those RH5's! GOOD LUCK with your frame! How's the 261 coming along? | | |
