0 members (),
82
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Both front fenders on my 42 have cracks about 8 inches long. What is the best way to fix this and what causes these fenders to crack like that? Thanks in advance.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had cracks in the fenders of my Willys Jeep that seemed to be caused by vibration and hitting the occasional tree. I fixed them by drilling a hole at the top of the crack (to relieve stress and stop it's spread) and then brazed the crack shut. That was before I had a mig welder but it held up fine. Now that I have the welding outfit I would probably weld the crack shut and grind it level.
The fenders are hung in such a way that they get exposed to quite a bit of stress and eventually they fatigue and crack. An extra brace rod or two may help a lot.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | I remember some discussion here a loooong while back about the possibility of the front fenders actually having welds as part of their forming. Seems to make sense that the welds would be the weak spots...right?
If the surround metal is in good shape, butt welding them back up should be no problem for someone experienced in patch panels, etc.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Are thet in the middle starting from the wheel well and moveing up ?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | The "weld" would not be the weak spot, it would be the metal right next to the weld that is weakened. DO NOT braze it, brazing needs flux, flux is acid and it is very hard to get it all out of there before painting. A brazed joint usually causes paint failures.
This is simply a vibration crack and unless you are going to drive the living hell out of the truck on poor roads and things like that, it will never happen again once it is welded.
To insure that it doesn't you could put a "backing" behind the weld made of a strip of sheet metal and weld through the crack into it.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | Ron, yes they start in the middle and go up. They are slightly dented in this location also.
Chris Simmonds 1942 Chevy 3/4 ton | | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | All of that vibration work hardens the metal , just like bending a peice of wire back and forth until it breaks. I'd welded mine up several times (I'm no expert) and it didn't finnally stop until I got another junk fender for a patch peice and replaced the surrounding metal with this "virgin" metal . It worked for me ! | | | | | Joined: Dec 2001 Posts: 92 Member | | Member Joined: Dec 2001 Posts: 92 | bear is right either braze them from the inside or mig them with solid wire and argon mixture donnot try with flux wire you will burn holes in the fenders.
Alan
Live every day to the fullest for tommorrow never comes!!!
