3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#1080164 01/19/2015 2:22 PM
Stovebolt Photo Moderator
Good Morning Folks,
I'm slowly getting the body panels straight and square for my 1947 AD. I picked up a solid hood but it has a few round dents, no creases. It seems to be pretty rigid as well. I'm going through a full restoration. Would you recommend splitting the hood now and replacing the rivets? Is it difficult to remove that top piece of moulding trim and re-install ?
Many thanks - any insight would be appreciated.
Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
amtrakjoe #1080203 01/19/2015 5:34 PM
Only comment I have ever read was that the hood halves can be a bear to re-align. But, if you are an experienced body man, go for it.
Drew
amtrakjoe #1080223 01/19/2015 7:17 PM
If the hood is as rigid as you say, I wouldn't separate the hood halves. I would remove the center hood strip, and strip and prime it. While you have the center strip off, you can see how much corrosion there is where the two halves come together. If it isn't excessive, I would remove the paint in that area as far into the crease as you can, than apply Ospho so that it seeps in between the two hood halves. This will stop any corrosion.
Carl
amtrakjoe #1080297 01/20/2015 3:23 AM
Thanks Guys. Sounds like I keep it whole and put the Ospho seep between the halves. I'm far from an experienced body man so I won't take the chance.
amtrakjoe #1082878 02/01/2015 2:16 AM
Lacking in experience also. What is Ospho?
amtrakjoe #1082889 02/01/2015 3:00 AM
amtrakjoe #1082931 02/01/2015 6:06 AM
I went to my local Dairy and asked them for 'milkstone remover'
which is nitric and phosphoric acid @ about 24-28%.
They buy it buy the barrel... I brought a jug.
I dilute that 1:1 with H2O and presto change-o it works just like the Ospho which is approx 14% Plus... I have XX strength Ospho on hand when I need it for no extra $$$$!
Give me ambiguity
or give me something else
CASO #1082961 02/01/2015 1:54 PM
Caso, what does the extra strength Ospho do that the regular doesn't?
Allen
1974 Stingray Corvette
amtrakjoe #1083001 02/01/2015 5:12 PM
I use it on non priority badly rusted items when I'm in hurry but I really got it cause it was cheaper than the ozpho at Enlgund Marine ...
Give me ambiguity
amtrakjoe #1083143 02/02/2015 3:30 AM
I pondered this gap at the center of the hood on my 47 AD. I did just what was suggested but I did pull the rectangular joining plate at the back (underside) of the hood. This took a lot of the rigidity out of the riveted joint and allowed my DA sander to get into the gap a little deeper. Then I ospho'd it. In the end there is the center hood trim strip that would cover any issues anyway. Good luck. Marko.
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
