6 members (carbking, Charles in CA, TooMany2count, 1955 1 Series, Donf, FAST55), 344 guests, and 5 robots.
Topics128,160
Posts1,057,054
Members48,463
I have a 54 that has no starter. can anyone tell me the delco part number for that starter
3B Offline
Hy brokentruck, welcome, I think the part number might be 1913369, at least that is the only solenoid starter that doesn't have the notation "exc. AT" in my parts book, hope that helps.
1107135 w/solenoid for 1954 Hydra-Matic
1107109 w/solenoid for 1954 3700/3900 (Forward Control Chassis - DUBL-DUTI?)
The two starters with solenoids have different length "snouts".
http://chevy.oldcarmanualproject.com/chevyresto/54153.htm
It looks like 1913369 was for 49-54 passenger car and also DUBL-DUTI for use with solenoid switch (but, without the switch). It's snout would not work with the HydraMatic.
3B Offline
Hy tclederman, thank you for the correction, it appears my 1941 through 1955 parts book does not list a Hydramatic starter, I did find 1107135 in one of my GMC books, but not 1107109. I was about to add to my post, but you beat me to it, thanks again
thank you shop shark and tclederman for the delco part number now all i haft to do is find one thanks again.broken truck
not much luck finding a Delco Remy 1107135 starter in the part stores.for a Chevy 3100 .is there any way to find out if that starter fit any other vehicle. thank you Bronkentruck,
You will most likely only find one used.
Post a Parts Wanted ad in the Swap Meet.
53-54 6v GM Hydra-Matic starter (my understanding is that 6v pos/neg does not matter with a starter motor)
This is an uncommon, if not rare, part.
Here's a low probability: call Jim Carter Truck parts for a used one
I think Gene at Restoration Hydramatics has a rebuilt one.
There was one on Craigslist about 3 weeks ago, that he had posted.
