0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 4 New Guy | | New Guy Joined: Jan 2015 Posts: 4 | I have a 54 that has no starter. can anyone tell me the delco part number for that starter | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy brokentruck, welcome, I think the part number might be 1913369, at least that is the only solenoid starter that doesn't have the notation "exc. AT" in my parts book, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1107135 w/solenoid for 1954 Hydra-Matic 1107109 w/solenoid for 1954 3700/3900 (Forward Control Chassis - DUBL-DUTI?) The two starters with solenoids have different length "snouts". http://chevy.oldcarmanualproject.com/chevyresto/54153.htmIt looks like 1913369 was for 49-54 passenger car and also DUBL-DUTI for use with solenoid switch (but, without the switch). It's snout would not work with the HydraMatic. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tclederman, thank you for the correction, it appears my 1941 through 1955 parts book does not list a Hydramatic starter, I did find 1107135 in one of my GMC books, but not 1107109. I was about to add to my post, but you beat me to it, thanks again | | | | | Joined: Jan 2015 Posts: 4 New Guy | | New Guy Joined: Jan 2015 Posts: 4 | thank you shop shark and tclederman for the delco part number now all i haft to do is find one thanks again.broken truck | | | | | Joined: Jan 2015 Posts: 4 New Guy | | New Guy Joined: Jan 2015 Posts: 4 | not much luck finding a Delco Remy 1107135 starter in the part stores.for a Chevy 3100 .is there any way to find out if that starter fit any other vehicle. thank you Bronkentruck, | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You will most likely only find one used. Post a Parts Wanted ad in the Swap Meet.
53-54 6v GM Hydra-Matic starter (my understanding is that 6v pos/neg does not matter with a starter motor)
This is an uncommon, if not rare, part.
Here's a low probability: call Jim Carter Truck parts for a used one
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | I think Gene at Restoration Hydramatics has a rebuilt one. There was one on Craigslist about 3 weeks ago, that he had posted. | | |
