0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Not really sure whats going on. Yesterday the starter worked fine for my first fire on my new 1949 chevy 3100 swb. All original besides being coverted to 12 volts ( no telling how long its been off the road but has some new parts on it). Then all the sudden it just stop doing anything but i could hear some clicking when pushing the button from under the hood. Today i took it off and bench tested it and it ran fine... put it back in the truck and hit the pedal and it tried to turn flywheel and then just stopped doing anything again but the clicking. Any ideas? Any help would be greatly appreciated. Really looking forward to getting this old truck fired up.
1964 impala ss 1949 chevy 3100
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pking75, welcome, remove clean and reattach both the hot and ground cables from the battery to the starter and wherever the ground cable attaches. You can also take your fully charged battery into a shop to have it load tested, hope that helps. | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Ordered me a new starter switch today. I know the positive cable is good and negative at battery... I'll check it on the engine.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Have you checked your battery voltage? The clicking you described sounds like the solenoid is trying to engage but lacks the voltage to do so. Just like 3B suggests, poor connections due to corrosion as well as loose connections can cause this to happen as well as low voltage. Hope you get it handled without too much pain!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | There is no solenoid on a stomp starter. None. You might have some bad cables. They will corrode up under the insulation. You might have a bad switch on the starter. And the brushes might be hung up or worn. You might, just might have bushings worn so bad the armature can touch the case magnets. And of course the battery might die under a load. All can be fixed and all can be tested. The "click" you hear can be a bad connection, a stuck armature or a bad bendix. However, the stuck armature will cause some damage. And it can be expensive to fix. Pull the starter. Two bolts and maybe, two cables, wire. get it on the bench and look at it. Some have been filled with water from just sitting around. If it will turn and if it will motor on the bench, like you have posted, then look for wear on the switch and then the cables and battery.
Steve H
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | This has been fixed battery was weak because generator is shot. Thanks fellas
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Thanks for the update with the solution. Best wishes for you and your truck!
