0 members (), 91 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
Can anyone post a drawing or pictures of the horn switch and wiring on the original steering wheel? The system is 12 V.
1952 Chevy 3100
...drawing click...
Since your going 12 volt you may want to add a relay
...12 volt horn relay...
Daveydo has a good drawing if you do not use a relay
Originally Posted by Davey Do
Thanks for the diagram, Joe.
I added to the previous illustration with a question, incorporating an excerpt from your diagram: Specifically, is the circuit completed at the point where the end of the spring meets the edge of the steering wheel mast?
http://s837.photobucket.com/user/da...amp;_suid=141741642445708749389373850446
Not sure what style horn you have, some if this info could change depending on your horn.
Thanks for the information. How does the ground wire attach to the steering column?
1952 Chevy 3100
Considering the current draw of a horn, one should always use a relay.
That being said, the horn has a single hot (12+) wire that travels from the horn through the steering column to a spring loaded carbon button located in the steering head (where the steering wheel attaches to the steering column shaft).
When the spring loaded horn button is depressed a slip ring on the steering wheel, makes contact between the carbon button and ground, completing the circuit and sounding the horn.
