| | | Forums66 Topics128,123 Posts1,056,653 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Can anyone post a drawing or pictures of the horn switch and wiring on the original steering wheel? The system is 12 V.
1952 Chevy 3100
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...drawing click... Since your going 12 volt you may want to add a relay ...12 volt horn relay... Daveydo has a good drawing if you do not use a relay Not sure what style horn you have, some if this info could change depending on your horn. | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Thanks for the information. How does the ground wire attach to the steering column?
1952 Chevy 3100
| | | | | Joined: Jan 2015 Posts: 6 New Guy | | New Guy Joined: Jan 2015 Posts: 6 | Considering the current draw of a horn, one should always use a relay. That being said, the horn has a single hot (12+) wire that travels from the horn through the steering column to a spring loaded carbon button located in the steering head (where the steering wheel attaches to the steering column shaft). When the spring loaded horn button is depressed a slip ring on the steering wheel, makes contact between the carbon button and ground, completing the circuit and sounding the horn. | | |
