1 members (baldeagle), 36 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#107973 05/21/2004 6:57 PM
Junior Member
Junior Member
I was recently given a '63 Chev II with no keys. Although the ignition was left unlocked, I would like to open the trunk!
I took out a door tumbler and found "9025" stamped on the barrel. I know the locksmith can cut a key ($12) but he's 30 miles away and I have a blank and a key cutter.
Anyone able to translate this number to specific key cutting data?
The money I save as a mechanic, I spend on medical bills!
#107974 05/21/2004 7:02 PM
Hi Jim,
Have you taken out the back seat and see if there
is an access hole large enough to reach the bolts
on the latch or the clip that holds in the lock assembly? This might allow you immediate access in case you don't get the numbers for the key code. Just a thought.
Truck Tinker
#107975 05/22/2004 3:49 AM
You need the code book. No way to de-cipher it from the number.
#107976 05/22/2004 4:54 AM
Code 9025 cuts to 223121. Do you have a way to set spacing and depth of cuts? If not, send me your snail-mail address and I'll mail you a couple of keys.
The only Chevy II I had was a wagon, with all locks keyed alike. Cars with trunks could have the trunk and glove box on a secondary key. Take the glove box lock apart and see if it has the same number.
Joe
#107977 05/22/2004 5:57 PM
Junior Member
Junior Member
The good news I was able to handcut a key per that info and the door locks are now usable. The bad news is the ignition must have been changed sometime over the last 40 years and some moron buggered up the trunk lock.
Oh well, back to the rear seat removal strategy!
#107978 05/23/2004 2:36 AM
You could cut all the remaining possible combinations (about 40?) and find one that works, then sell all the rest to a car thief. :mad:
Paint & Body Shop moderator
