1 members (59 fleet),
62
9
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | I was recently given a '63 Chev II with no keys. Although the ignition was left unlocked, I would like to open the trunk!
I took out a door tumbler and found "9025" stamped on the barrel. I know the locksmith can cut a key ($12) but he's 30 miles away and I have a blank and a key cutter.
Anyone able to translate this number to specific key cutting data?
The money I save as a mechanic, I spend on medical bills!
| | | | | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | Hi Jim, Have you taken out the back seat and see if there is an access hole large enough to reach the bolts on the latch or the clip that holds in the lock assembly? This might allow you immediate access in case you don't get the numbers for the key code. Just a thought.
Truck Tinker | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need the code book. No way to de-cipher it from the number. | | | | | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Code 9025 cuts to 223121. Do you have a way to set spacing and depth of cuts? If not, send me your snail-mail address and I'll mail you a couple of keys.
The only Chevy II I had was a wagon, with all locks keyed alike. Cars with trunks could have the trunk and glove box on a secondary key. Take the glove box lock apart and see if it has the same number.
Joe | | | | | Joined: Feb 2003 Posts: 24 Junior Member | | Junior Member Joined: Feb 2003 Posts: 24 | The good news I was able to handcut a key per that info and the door locks are now usable. The bad news is the ignition must have been changed sometime over the last 40 years and some moron buggered up the trunk lock.
Oh well, back to the rear seat removal strategy!
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You could cut all the remaining possible combinations (about 40?) and find one that works, then sell all the rest to a car thief. :mad:
