| | | Forums66 Topics128,201 Posts1,057,276 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 12 New Guy | | New Guy Joined: Jan 2015 Posts: 12 | Hoping someone can help me out , I Have the stock enclosed diveshaft and rearend in my truck and need to change the spider gears and side gear, does anyone know if the Canadian trucks ( 1300) and the USA trucks (3100 ) have the same size spider gears and side gear ? or how many splines are on the end of the US model axle, I know the carriers are different because you can not use the patrics ring and pinion set on Can truck because of ther different carrier, thanks guys and this site is awesome and a real help with my frameup restoration . Mike
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike King, welcome, I was not aware of a difference in the differential carriers between Canadian and American trucks of that vintage. That being said I know someone over here on the mainland that may be able to help you with the parts you're looking for, hope that helps. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those parts are really hard to find because they are not reproduced. If you get them, keep them some place safe! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I installed Patricks ring and pinion in a Canadian rear end which did require minor modification. The ring gear bolt circle on a Canadian carrier is 6.188" and the bolt circle on U.S. carriers (and Patricks ring gear)is 6.062". Elongating the holes (on your Canadian carrier) 1/16" towards center will make it fit which I did with a 3/8" endmill. The washer spotface is large enough that it requires no modification. Here's some pictures. I remember that my spiders had a brass/bronze? washer behind them that I saw no mention of in U.S. literature so I suspect these are unique to Canadian rears. Good luck.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The bronze "washer" is a spacer only used if required. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | On my Canadian 38 Master, those gears have the brass washers. I have a set of NOS gears and they measure out the same without the washers as my originals with the washers. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Maybe all CDN rears used them then. | | | | | Joined: Jan 2015 Posts: 12 New Guy | | New Guy Joined: Jan 2015 Posts: 12 | Thanks for the responses, this site is great !!!!!! | | |
