| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 1 Moderated | | Moderated Joined: Jan 2015 Posts: 1 | I have a 72 PU that I am restoring, it was orginaly a 3 speed on column. Am converting to a 5 speed in floor. I am looking to change out the part on column where the shifter was with one that does not have the place for a shifter. Does amyone know what years will interchange, other than 67 through 72? Thanks | | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 | You could cut the nub off the collar & filler it in w/JB weld/body fill. Much cheaper & less work. Here's some pics I found on line......joe nub ground off Hole filled & sanded Primed
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Go visit the 67-72 chevy gmc forum. Their classified has some for as little as $50 complete. | | |
