Brrrr
place holder
4 members (DennisM, ShopRag, Wayne67vert, 1 invisible), 139 guests, and 3 robots.
Topics128,271
Posts1,058,415
Members48,485
#1079168 01/14/2015 6:18 AM
I bought a parts truck with a 2-speed rear end that I want to put in my '46 2-ton. Before anyone jumps in to tell me it won't make the truck go any faster, I know that. I use the truck in the hills of western MA and could use some lower gears when it's got a full load.
The question is will the two-speed differential fit in the one-speed housing? If it will, that would save a lot of work. If not, would the brakes interchange or would I be on the hook for new parts?
Thanks.
3B Offline
Hy Ed Hotaling, are the two trucks both "Art Deco" style? Do the two trucks have the same GVW? According to my Fel-Pro gasket catalog the single speed and two speed rear axles from 1937 to 1954 do not use the same gasket, so I would surmise that the two speed will not swap into the single speed housing, hope that helps.
Yes they are both Art Deco 2-tons. I was really hoping I could just swap the differentials.That would make the job and down time a lot quicker.
The answer is no.
The 2 speed housing doesn't bolt up to a single speed axle.
Brakes would depend on who made the axle.
Changing the entire rear housing is not a very difficult task. Just put the vehicle on two good jack stands and make the swap.
https://plus.google.com/photos/1081...3611568210&oid=108197707187186692269
We routinely change an entire tandem in a half a day.
