7 members (Danielbolt, Gdads51, SmalltownTRKGuy, Charles in CA, Bill Hanlon, Peggy M, 1 invisible),
90
Mod | | | Forums66 Topics128,092 Posts1,056,455 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I bought a parts truck with a 2-speed rear end that I want to put in my '46 2-ton. Before anyone jumps in to tell me it won't make the truck go any faster, I know that. I use the truck in the hills of western MA and could use some lower gears when it's got a full load. The question is will the two-speed differential fit in the one-speed housing? If it will, that would save a lot of work. If not, would the brakes interchange or would I be on the hook for new parts? Thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ed Hotaling, are the two trucks both "Art Deco" style? Do the two trucks have the same GVW? According to my Fel-Pro gasket catalog the single speed and two speed rear axles from 1937 to 1954 do not use the same gasket, so I would surmise that the two speed will not swap into the single speed housing, hope that helps. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Yes they are both Art Deco 2-tons. I was really hoping I could just swap the differentials.That would make the job and down time a lot quicker. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The answer is no. The 2 speed housing doesn't bolt up to a single speed axle.
Brakes would depend on who made the axle. | | |
