| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Where can i find cross reference info.(on this site)Reguarding transmissions? I have a 55 wagon manual trans,and want to know if it will work in my 56 3200 also manual. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I don't think you'll find 'cross reference' material specifically, but the transmissions between cars and trucks were basically the same and what you propose will be fine - might take a different driveshaft length and/or shift arm mods, but it's really the same trans
Bill | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Thanks bill,physical length looks to be the same. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | As Bill stated, same transmission with minor differences. The car trans mounts with 4 bolts into the bellhousing. The lower bolts on the truck thread into the trans. Just use a longer bolt with a nut. The side cover is different, use the side cover from the truck. While you have it apart check the 2-3 shift fork. It is a common wear area and can cause popping out of gear. There may be a difference in the spedo gear also. Some of the early trucks had a metal spedo gear, it will not work in a car trans. You should be able to find a suitable plastic gear to match your rear end ratio. Fred
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't really add anything to what Bill and Fred have told you, other than I have a Station Wagon transmission in my '55 3200, other than the side cover issue and the bolt issue on the bell housing, it was a direct bolt in.
Bill Burmeister | | |
