0 members (), 93 guests, and 4 robots.
Topics128,265
Posts1,058,363
Members48,485
#1079005 01/13/2015 7:02 AM
I was told by another bolter that has the same mini HEI from Langdon that a .060 gap is too much and puts too much strain on the coil. He said my plugs should be .045 and that's pretty much for all HEI equiped vehicles.....Tom states .060 but I was told that was "wrong thinking now a days". What's the scoop?....1956 235 engine 3100 truck ....thanks!
You are not running a modern engine, so "wrong thinking now a days" doesn't apply. .060 in my opinion.
Drew
.060" and even .080" gaps were recommended on some engines in the late 1980's when the fuel injection mixture was so lean that some misfires were occurring with the usual .045" gap due to a lack of properly atomized fuel between the insulated and the ground electrodes. The coil on most 50KV+ HEI systems will fire a plug reliably with the ground electrode completely missing, so stressing the coil is not an issue. Any gap from .035" to .080" or more will run a stovebolt engine with a carburetor- - - - -set it anywhere you choose!
Thanks...I'll set my new plugs at .060 and forget about the coil being over worked.
Steve
