5 members (Phak1, BC59, Gdads51, Wally / Montana, MickeyP), 84 guests, and 1 robot.
Topics128,049
Posts1,055,667
#1078 03/29/2003 4:45 PM
I have a 66 GMC 1/2 ton 4x4 with a 305 V6 in it. It was siezed when I bought it but I have since freed it up. I am in the process of rebuilding the motor but can't find anything on what the crankshaft diameter should be on the connecting rods and at the main bearings. Anyone know where I can get this info? I have tune up specs but not rebuild specs. Thanks! :confused:
1965 Chevy C-10 Longbed Stepside
#1079 03/30/2003 2:12 AM
The main diameter is: 3.1237"-3.1247" on#1,2,3 and 3.1239"-3.1229" on #4 and the rods are:2.8112"-2.8122" get back to me if you need other specs.
#1080 03/30/2003 9:47 AM
#1081 03/30/2003 3:56 PM
Thanks for the info. I measured the crank and the pistons to find that my motor (with 125,000miles) has never been turned or bored smile . Thanks again for the info!
#1082 03/31/2003 8:01 AM
GMC V6: Built to last. smile They could go about 300,000 miles before a major overhaul. eek You just don't see that any more. Iron has gone the way of the dodo. Its all about the aluminum and composit plastics now. frown
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
