1 members (Phak1),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | my doors were deteriorated inside and the door glass just wobbles around. since nothing original is left in there i don't know what i need to replace. any vendors sell a complete door kit with all the pieces i need? if not could someone tell me what goes in there to keep the glass from moving around? A scan from a shop manual would be cool. i have a 48 GMC, doors without the vents. Thanks!
1948 GMC 250 Series Flatbed
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Chevy Duty sells a door rubber kit that has everything you need to do both doors. I just did mine. There's a felt piece that gets attached to the chrome trim on the inside of the door; a rubber piece (sort of like a wiper blade) that goes in a slot on the door and "wipes" the glass on the outside; a rubber seal that goes around the door frame on the cab and is held on by two metal trim pieces that are held on with screws; a rubber seal that goes around the door itself and is held on with glue; a rubber piece that goes on the bottom and is held on with the door moulding; and the "felts" that go inside the door around the window channel. The kit costs $167.95 and includes everything you need to do both doors. And boy does it make a difference. All the rattles are gone. If you want, I can take some pictures with the digicam and put them on a web page so you can see what I'm talking about. [ 01-26-2002: Message edited by: baldeagle ] | | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | thanks, a pic would be great if you find the time. i was wondering about inside the door. I pulled out some rusted channel type metal pieces (through the hole in the bottom of the door!) where did those pieces fit? do they guide the glass inside the door? Where can i get them?
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | All I can say is thank god for CA trucks. With your situation I don't know how you would ever get it operating again.
But, contact, mothertrucker, he is on this forum and can be found through the swapmeet. I bet he can sell you all the moving parts necessary. Whether you can actually make it work in a rusted out shell of a door, I cannot tell you. Good luck. I think I might have just bought some doors that worked for replacements.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | i know, its crazy. the doors outside are really not that bad just some holes at the bottom. the windows actually roll up and down!!! don't ask me how, but they wobble back and forth like crazy (obviously). i might have to break down and just get the manual for this truck so i know what pieces i need that are missing. i just have no clue on some of these things. i wasn't around when these trucks were new and all the ones ive seen at the shows have been customized. i will try to contact mothertrucker. thanks.
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Hi Onetongmc:
The channel that you pulled out the bottom of the door is the (vertical door glass channel guide)and you have (2) per door. Theirs one that is tack welded to the front inner skin of the door jamb and the other is at the rear of the door jam and it's removeable. The rear guide has (3) screws securing it to the door skin. You can see two screws side by side down from the latch when you open the door and their another one hidden almost at the top of the window viewing area on the inside "right under the door glass channel. So to get to the inner screw you'll have to remove the glass and pull what's left of the glass channel out. Those vertical guides keep the glass stable when rolled down and if one is falling apart I can see why the door glass is flopping around. Chevy Duty sells the removable rear channel guide. If it's the front that's falling apart, just have someone weld in a rear guide up front. I did that on my doors.
Joe
