4 members (Wheelie, Otto Skorzeny, Ponchogl, walter74), 91 guests, and 1 robot.
Topics128,055
Posts1,055,785
#1078642 01/11/2015 5:29 PM
7
7 Offline
Am I destined to shell out about $500 for an original cotton wireing harness for my 1950 3100 ?
Whats the best one to buy, ease of installation ? Tips?
Any help would be appreciated.
John.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
If you are doing a 100% restoration than talk to these folks.It may not be as pricey as you think.
www.vintagewiringofmaine.com
If you just want to upgrade there are plenty of after marketers selling all kinds of harnesses.
Drew
7
7 Offline
Thanks friend I just left Joe a message to call me.
All Original
Rhode Island wiring has a complete fabric coated harness for $411, for comparison.
8
8 Offline
For my '48 Loadmaster 1.5ton I went with the "original' cloth style wiring harness w/turn signals from Jim Carter. I knew somethings would probably be different as they don't list a harness for my application. The main differences are; most of the '48 fuses are omitted (no more head light fuses)
The fuel sending unit wire is too short.
No courtesy light wire, or steering column horn wire
Other then that it looks and works great for me.
It is $500 as opposed to $750 & $950 I was quoted from some of the popular "wire harness" vendors here.
_________________________
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
For the 48 2 ton I had the harnesses made at Narragansett Reproductions, in RI as well.
They make original (100 point) harnesses and will customize them as well. They made a main cab harness with directionals, 1 wire alt, and a volt meter instead of ammeter. Also added a branch for the automatic trans and it cost less than the high end plastic harnesses sold by the online suppliers.
Also made a rear harness for the 12ft flat bed to my drawings (original had 1 tail/brake light) with individual brake, tail, directional, backup and side mounted gas tank.
Looks original and their over braiding is great.
