1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Am I destined to shell out about $500 for an original cotton wireing harness for my 1950 3100 ? Whats the best one to buy, ease of installation ? Tips? Any help would be appreciated. John. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If you are doing a 100% restoration than talk to these folks.It may not be as pricey as you think. www.vintagewiringofmaine.comIf you just want to upgrade there are plenty of after marketers selling all kinds of harnesses.
Drew
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Thanks friend I just left Joe a message to call me. | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Rhode Island wiring has a complete fabric coated harness for $411, for comparison. | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | For my '48 Loadmaster 1.5ton I went with the "original' cloth style wiring harness w/turn signals from Jim Carter. I knew somethings would probably be different as they don't list a harness for my application. The main differences are; most of the '48 fuses are omitted (no more head light fuses) The fuel sending unit wire is too short. No courtesy light wire, or steering column horn wire Other then that it looks and works great for me. It is $500 as opposed to $750 & $950 I was quoted from some of the popular "wire harness" vendors here. _________________________ | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | For the 48 2 ton I had the harnesses made at Narragansett Reproductions, in RI as well. They make original (100 point) harnesses and will customize them as well. They made a main cab harness with directionals, 1 wire alt, and a volt meter instead of ammeter. Also added a branch for the automatic trans and it cost less than the high end plastic harnesses sold by the online suppliers. Also made a rear harness for the 12ft flat bed to my drawings (original had 1 tail/brake light) with individual brake, tail, directional, backup and side mounted gas tank. Looks original and their over braiding is great.
