1 members (Jon G), 136 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
Hi Guys. I have gone through two after market gas gauges for my 12v 54 and I'm sure some of the problems with them were my fault but as I have tried to fix them I can see they are pretty cheaply made. Does anyone have a recommendation for where to buy a high quality gauge?
Post in the Parts Wanted forum.
And, look on eBay for new/used 54/55 fuel gauge.
Be sure to connect the power lead to the post behind "E"/Empty (+ lead, if Chevrolet). You will quickly fry the gauge is you connect the power lead to the post behind "F"/Full.
are these replacements for your cluster, or under dash?
for the cluster. I'm sure I have fried one of the gauges. I have one that is out of the cluster to bench test but I'm not sure where the ground lead from the ohmmeter goes.
