5 members (Nuts&Bolts, Joe H, baldeagle, Shade Baby, dt235sd), 66 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#107835 08/19/2002 6:06 AM
1) The small areas that are more a discolored patch than anything else. What is the best way or product to use? Trying not to make the metal too thin or grind it away.
2) I pulled the inner kick panels and they are covered with surface rust, the kind that feels gritty to touch. This is a fairly tight area and I do not have a sandblaster. Suggestions?
3) The same problem on the inside of the rear cab behind the door latches and under/inside the dash. Under the original sound deadner the lt grey paint is still shiney & pretty.
Thanks for any suggestions
Brad
#107836 08/19/2002 7:01 AM
Go to this page ... Zero Rust
It seems like it's exactly what you want. From Zero-Rust Prep Step Concentrate which will soften the rust for easier removal and then solidify the remaining rust for a tighter surface which will maximize the adhesion of at least two applications of Zero Rust. Once Zero Rust is applied and cured you can then prime and paint the existing surface. I'm selling the stuff but only because I use it widely and am astonished at how reliable it is. Here's the bonus it's relatively cheap for what you get ...
