8 members (Hotrod Lincoln, JoergK., tclederman, 32Fordpuchoptop, Buckeye998, Gray_Ghost, carbking, 1 invisible),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,192 Posts1,057,358 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | Does anyone know of a source for these rare original bushings? Mine are 2"long x 1 1/2"tall with bump 1 3/8 wide with a 7/8 hole . JC has a 9/16 hole
52 suburban 48 Palace
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | JC has those bushings for the two styles/sizes of sway bars used on 47-55 GM panel-body trucks (47-51 & 51-55).
Maybe your assembly is from the other style. It is worth a call to JC. If you have already checked this with JC, just ignore this post.
JC's bushings have worked on the two original sway bar sets on my 54 trucks; although, the bushings in the recent set I used were a little smaller in width than the set I bought 10 years ago.
I think the tie rod diameter from 46-55 was 3/4" diameter.
| | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | Thx's I did call JC and they probably spent 20 minutes with me on the phone. They even pulled stock off the rack and measured it. You are right they are smaller in width. and now the tie rod diameter is smaller to 9/16. Curious did your bushings have the top bump?
| | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | Here's what I found to be the closest to factory. Eckler's has both a Polyurthane and rubber bushing. The Poly part is A7265 the rubber is part # 54930. The Poly is a little narrow, but fits the bracket perfect. And Yes these a early Corvette part's too. I was told that the rubber bushing fills the bracket more like the original. I"ll try that on my other sway bar.
