1 members (dt235sd), 60 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#1078143 01/09/2015 3:31 AM
Hi all, I am rebuilding the Rochester 1bbl carb on my 235 (7003526). The new accelerator pump with the kit is a bit loose in the bore, the seal is a little bit smaller than the I.D. of the bore it goes into. I was assuming it should be a snug fit, but maybe I'm wrong. Is it supposed to be loose? If not, will the seal swell up a bit and become a tighter fit? The accelerator pump seal is pink in color, I'm not sure if it is leather or rubber or whatever. Anyone here know more about this? Thanks for any help.
Lemmm117 #1078145 01/09/2015 4:02 AM
You tube videos from Mikescarbs says yes, can be loose some models. My Rochester 2G was loose except for the bottom section of pump tube. I'd chek out the videos for your model. Good luck. Jim
Lemmm117 #1078146 01/09/2015 4:08 AM
3B Online: Content
3 Online: Content
Hy Lemmm117, if the carb kit has been sitting on a shelf for a long time the accelerator pump plunger may have shrunk to a minimum size, it should plump back up once it is immersed in fuel. The synthetic cups on the plungers do not seem to have the shrinkage issue. I don't know what issues may arise from the ethanol in today's fuel, I imagine most of the carb kits in circulation today were assembled long before fuel had any ethanol in it, hope that helps.
Lemmm117 #1078153 01/09/2015 4:41 AM
Riding in the Passing Lane
If its a leather seal you need to soak it in oil for a few hours. It should not be loose in the bore. You can try it by putting some gas in the bowl & putting the pump in the bore. It should squirt gas.
1972 Chevy c10 Cheyenne Super
Lemmm117 #1078280 01/10/2015 12:34 AM
Gas Pumper
Gas Pumper
There is a rebuilding the Rochester B Carb slideshow direct from GM (from back in the 50's) here:
http://devestechnet.com/Home/RochesterCarb
Thanks to Brad Allen! Someday I hope to write a very specific how-to, but for now, GM's word will have to do! haha
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
