3 members (Dennys28, Southerntruck, KEVINSKI), 82 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#107814 11/20/2003 12:46 PM
Junior Member
Junior Member
I do not know what the strip is actually called but it was fastened using HEAVY metal staples to the inside door window frame on my 1950 Chevy 1/2 ton PU. It has a felt piece that keeps the window snug and keeps it from rattling.
After buying an after market strip, I can not figure out how to attach the new piece. I do not know of a staple gun THAT big and powerful to reattach the new strip.
Any suggestions or work-a-rounds?
Thanks!
Richie West
On my 50 I drilled very small holes through the weatherstrip and window trim and used some very small flathead sheetmetal screws my hardware store had. About 4 or 5 per window.Also used a little 3M weatherstrip adhesive. I used some masking tape wrapped around the whole shebang to keep everything lined up while I drilled and screwed.Once installed you can't see them.
Thanks JR!
Boy, I totally forgot about that project. About ten years ago I did exactly the same as what you, brjr51, did. Tiny screws heads become hidden once they snug down into the felt material.
Craig
My kit included a drill bit and staples ... drill the holes, place the staples in and bend them over - by hand, I guess.
I haven't installed mine yet because I'm going to cover the mouldings with vinyl first ... and then install the felt strips.
Should I forget about attempting the staples and use screws instead??? It sure sounds easier!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Alan,
Yes, I would forget staples. I believe once in place you can torque the screws in a lot further than the staples. The key is to make sure they go way down into the felt so that you don't have any chance of scratching either the window frame or glass.
Craig
Thanks, man.
I was skeptical about those staples to begin with -- not being tight enough, too difficult to line up, etc.
These groups are priceless!
grin
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Hey!
I installed mine today, using the small sheet-metal screws ... it worked perfectly!
grin
And now, when I get around to covering the mouldings with vinyl, it'll be a cinch to remove and replace the felt strips!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
