3 members (JW51, mo2cyl, 1 invisible),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | What is the proper color to paint a 1959 235 I6. The engine is in a 1959 GMC 9314, which is a half ton, and Canadian.
Canadian trucks used the same drivetrains as Chevrolets. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | according to an article in the old 'pickups and panels' - the truck 235 in the 50's is gray - assume it'd be the same in Chev or GMC
Bill | | | | | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | What shade of gray is it?I have been trying to find the proper shade of gray for a 283 in a 1963 truck.The factory manual shows gray for the 283 and Alpine green[Detroit Dsl.] for the 327. A paint code or chip would be of great help. | | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | Yes, a paint color or code would help, or is Chevy Engine Gray well known?
Is this the gray with a hint of green? | | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Do a search in this site for "engine Paint" I know AD's were a grey blue and 261's were a green. Do not know the case for task force trucks. The vendors sell this paint also. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | one of the automotive rattle can outfits has a 'Chevy engine gray' that's what I use - don't know that it's "correct", butI've never seen a code for it either . . .
Bill | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I suspect that chevy wasn't too concerned about the exact shade of gray they used and about any would work.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I ordered my engine paint from Jim Carter and was happy with the color. There are also a number of old parts suppliers who sell the correct gray engine paint if you want to stay with original. | | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | Thanks everyone.....
It is now painted gray.
My boss still swears that it should be a pale green, but my restoration shop says that a 261 I6 would be green and a 235 I6 should be gray.
Now I agree with above, the Chevrolet didn't seem consistant with the shade. | | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | There are some pale green 235's. I bought a block out of a '61 Biscayne. That car motor was green. Could be the color difference is between a truck and a car motor or for later year 235's? Not sure about that. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Car 235's should be blue.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | Well...the paint code for chev 235 engine grey is PPG DAR 32560, courtesy of Bob Adler. All bets are off for a Canadian GMC though (I think they were green; I don't have a code for that one). Hope this helps.
Tom. | | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | Thanks for the paint code.
What makes you think a Canadian GMC 235 should be green?
I have been told that a 261 was green, and I have also been told a 235 should be green? | | |
