Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Peggy M, homer52, TUTS 59, JW51), 570 guests, and 1 robot.
Topics126,776
Posts1,039,274
Members48,100
Most Online2,175
Jul 21st, 2025
Hey Guys, Im trying to make new oil hoses for my S-6 Oil Canister. I need a longer line due to remote mounting of the canister. I took the line to several hydraulic hose shops and they can't match up the swivel end that threads into the filter. Does anyone know where to get that fitting?
Many of the original fittings on these trucks were made by Weatherhead have you tried one of their distributors?
Y
Moderated
Moderated
Y Offline
Brad
1st time on the forum so bear with me...I too am looking for some advice on my 54 , 3100 1/2 w/235.
I found a NOS AC canister filter kit in the box - came with canister, and two hoses and instructions, my isue- NO fittings... tee off engine( #107 tee) as noted in AC instructions that attached to block with supply to both the canister and the in-dash guage is missing. Looking for this TEE fitting.
these are nothing special, I don't know exactly what you need, but Napa should have it all. You will find while working on these trucks that you have to find/make a lot of your own things. Use your own common sense, think things out a bit. It isn't really like newer cars where everything comes as a unit or a set.
That swiveling 1/8" pipe thread fitting is a scarce one. Here's a work-around. Install a brass adapter into the filter housing with a 1/8" pipe male thread and a #4 (1/4") female inverted flare. Then use a 1/4" inverted flare male fitting on the filter end of the flex hose.
The engine block end can use a non-swiveling 1/8" pipe male fitting.
Try this
...link...
Do you need sealer when connecting the oil lines? Maybe #2 Permatex?
Dennis
40 Chevy 1/2 ton
Brass-to-brass fittings should not need a sealant, except:
You could use a pipe sealant (sparingly, or teflon tape) on pipe-thread fittings, especially on brass to cast .
Thanks Tim. Yes, it was the connection into the block and filter I was talking about.
Dennis
40 Chevy 1/2 ton
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.152s Queries: 14 (0.055s) Memory: 0.6366 MB (Peak: 0.7160 MB) Data Comp: Zlib Server Time: 2025-09-22 16:12:26 UTC
Valid HTML 5 and Valid CSS
