1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My truck (stock 1949 216) has been running funny. A while back I noticed a bit of a stumble at acceleration and occasional back fire. My exhaust is not good so it's hard to tell if it's throught the carb or exhaust. I've since replaced the cap, rotor, plugs, wires, points, condenser, fuel pump and filters, rebuilt the carb, set timeing and adjusted lifters. Compression is 120-120-119-120-119-120. I thought I'd fixed it (for about a week) but I'm getting the same simptoms. The thing is it comes and goes. It'll stumble, backfire, and run like crap one day and the next it'll run like a dream. Last night it was terrible, missing and backfireing. This was the first time it had a constant miss. I pulled each plug wire but got the same subtle miss on each cylinder so I don't think it's in the ignition. I fired it up this morning and drove it around and it ran great! Is this a sticking valve? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I use an inductive timing light to check my ignition. Each plug wire should have steady flashing with no skips as the engine runs. Also, have you checked that the vacuum advance is working? Distributor should physically turn when you rev the engine. I had a similar problem as you last year and ended up replacing the distributor. Runs great since then, fires right up even after sitting a couple days.
Ed
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Concur w/Ed, 1st thought is a vacuum leak,possible at the dist vacuum adv unit, the line to it or at the manifold.
Plug the vacuum line fitting at the manifold and test.
Another test to try is while it's idling, remove the air cleaner and cup your hand over the carb in an attempt to cover it up. This will enrich the fuel/air mixture. If idle picks up you've got a vacuum leak, if it trys to stall out you may not.
Like Ed said with the vacuum line connected the whole dist should rotate when you increase rpm, make sure.
Good luck Dave | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd take the coil wire out of the coil and look at the end of it to make sure its ok. Also check to see if the coil has any oil leaking out of the center. I would suspect something ignition related. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My truck starts right up after setting for two days in this cold if I pull the choke out and I don't even have to give it gas. No problems there. Vacuum advance works right. I've checked for vacuum leaks, including plugging the vacuum line at the carb base, all is good. The miss at idle last night was steady, like a dead cylinder, but each plug wire I pulled had the same effect. I do have a replacement distributor that I need to rebuild. Cold weather coupled with no garage makes it slow going
So do you not think it's a sticking valve?
Don I replaced the coil wire and the old and new wires look fine. The coil is dry, it is the only thing I haven't replaced.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | ah, you got the gremlins this week...
| | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | | | |
