1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 17 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 17 | I have been inactive for long time and getting back to work on my Stovebolt. I replaced my 216 CID with what I was told is a 235. I am having no luck finding the year on various websites. Hope someone can help.
Engine markings are:
3897004 GM 2
conv1 E2156 0290364T56X
From the 56 in the # I assume it is a 1956 engine. maybe passenger car?
Can someone help? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | T56X = 3100/3200 1956 Tonawanda truck engine with standard transmission. http://chevy.oldcarmanualproject.com/chevyresto/56070.htmwas conv1 E2156 0290364T56X all in one place? E2156 (this might not be a normal date code) E = May 21 = 21 56 = 56 | | | | | Joined: Feb 2011 Posts: 17 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 17 | TC, No, the conv1 E2156 is cast on the engine block side. the 0290364T56X is stamped on the lip the distributor sits in.
Your help is much appreciated. Now I need to learn what a Tonawanda truck is. See!? I told you i am a newbee. My first guess- Is there a "tonawanda" plant" located in Tonawanda?
| | | | | Joined: Feb 2011 Posts: 17 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 17 | AHHHH Thanks to Wikipedia. Found Tonawanda:
Tonawanda Engine is a 3 facility, 3.1 million square feet; 190 acres General Motors engine factory in Buffalo, New York.
What would we do without Wikipedia and the good, helpful people on this planet? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F = Flint, Michigan truck engine assembly plant (where the engine was assembled) I think the engine blocks and heads were cast in a separate GM foundry/casting plant. Maybe someone knows for sure? The reason that I asked about the location(s) of the two codes is that it is common for someone to have a replacement engine. A replacement engine might have a variety of codes pressed/stamped into the block, usually because the title/registration might be the old/original engine serial number (a poor choice because engines were often changed). People have reported a variety of styles of codes in replacement engines. I have one 1954 block where the code has be roughly ground off - it has no engine serial number. The codes you posted are: - the block date casting code (cast as part of the block) - the engine serial number (pressed/stamped into the block) Here are locations of various codes on 235/261 blocks/heads The codes that are sometimes of interest when identifying an engine are: - block casting code - block date casting code - head casting code - head date casting code - Engine Serial Number | | | | | | Neverdone Unregistered | | Neverdone Unregistered | I had this same problem a couple years ago and I never did get it answered . The Casting numbers are the same for both the 235 and 250 . I think someone finally told me that one had domed pistons and on had flat top pistons [ in stock applications] I never did find out what I had , and have to believe there are other more obvious ways to tell the differences . | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Nevedone I think you mean 230 and 250, not 235. Right? They are the same block, and same bore I think (3.875), with different strokes.
Professional Novice
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Frank50,
I think you are correct, Neverdone is most likely referring to a 230 and a 250.
| | | | | | Neverdone Unregistered | | Neverdone Unregistered | Frank50,
I think you are correct, Neverdone is most likely referring to a 230 and a 250. Frank , Tc yes of course , my mistake . I started a thread on this about 4 years ago that went no where but always wondered about my stated premise .. is there an easy way to differentiate between the two engines ? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Neverdone,
I remember that discussion regarding exterior differences between 230 and 250 engines. As you/I recall, no one had a definitive answer.
| | | | | | Neverdone Unregistered | | Neverdone Unregistered | Neverdone,
I remember that discussion regarding exterior differences between 230 and 250 engines. As you/I recall, no one had a definitive answer. Which I guess TC answers at least the first part of Sandollars question.. Dan | | |
