2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
#1077405 01/05/2015 5:17 AM
I'm working on a 51 gmc 1/2 ton. Not much original at this point. I boxed the frame and installed a Mustang II front suspension. The front hub to hub width measured 57-5/8. I'm trying to determine what width the rear axle should be? I found a post referring to using a 62" axle. Does this sound right? I want to use a ford 8.8 or 9" with disc brakes. Any donor suggestions? Oh, and the specs show the wheel base at 116" but I understand the wheels won't be centered properly in the rear. Should I move it to 117?
V
V Offline
I cut a measuring stick to represent the original axle width inside measure behind the brake dust shield left to right. Took this stick to a junk yard and started checking out cars that had late 60' and early 70's 10 bolt rear ends. The closest I found was a 1970 Oldsmobile rear end 272 gears, came within 3/4" of the original width. Works real well and the width looks stock. Looks good bolted custom driveshaft to a 700r4 & 4.3 v6.
Consistently gives me 22mpg.
http://s150.photobucket.com/user/vickraft/media/024-1.jpg.html?sort=6&o=5
Well I don't have an axle to start with. I think I'll bolt my box together and put the fenders on it. Then I'll mock up a tire and take some measurements. It is difficult when all you have is a frame and you have no intention to go stock anything . I started with what was left after a body shop used it for parts... Not much.
Wheel back spacing, etc all comes into play.
I found what I was looking for. If anyone else is curious check out art Morrison site and open the frame spec sheet for 47-54 chevy.
V
V Offline
Very good references, these guys have the right stuff. Glad to hear you found what you needed. My truck is now in storage for the winter and there are days I wish the winter was over so I could open the garage door, rev it up a little and cruise all day. Good luck.
