| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I have a 49 1/2 ton and starting to work on steering problems (steering wheel has 1/4 of a turn slop in it) but while I was on the under side looking around I saw that the truck has no shocks on it. I can see where there has been shock brackets added but never any shocks. My question is do I need to take a measurement from top bracket to bottom bracket or is there a standard shock for a 49? I will need them for the front and back. Thanks for any info. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The problem is that you would need both the full compression and full extension lengths. On the 49s, the factory shock would have been the lever style, rather than the tubular "aircraft" style shocks found on the '50 and later. However, since the shocks for the '50 are still available, that's what I would suggest you go with.
Bill Burmeister | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | OK, thanks, went to O"Reileys an they told me to bring my old ones, They didn't have anything for a 50 model. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Rockauto has them, Gabriel and Monroe, for the '50 3100, instock, for $13-$15 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | O'Reilly shows them in Monroe, $21.99 for the rear, $23.99 for the front. They can usually have them next day, no shipping cost. Or, if you get to the store early enough, possibly even same day, depending on how far they are from the d/c and if they have them on hand.
Bill Burmeister | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Great, I will get me some ordered today, thanks guys | | |
