Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jmoore, frogfarmer, Jon G), 105 guests, and 4 robots.
Topics128,288
Posts1,058,574
Members48,492
#1077531 01/05/2015 9:59 PM
I have a 49 1/2 ton and starting to work on steering problems (steering wheel has 1/4 of a turn slop in it) but while I was on the under side looking around I saw that the truck has no shocks on it. I can see where there has been shock brackets added but never any shocks. My question is do I need to take a measurement from top bracket to bottom bracket or is there a standard shock for a 49? I will need them for the front and back. Thanks for any info.
red49 #1077546 01/05/2015 10:42 PM
The problem is that you would need both the full compression and full extension lengths. On the 49s, the factory shock would have been the lever style, rather than the tubular "aircraft" style shocks found on the '50 and later. However, since the shocks for the '50 are still available, that's what I would suggest you go with.
Bill Burmeister
LONGBOX55 #1077592 01/06/2015 1:27 AM
OK, thanks, went to O"Reileys an they told me to bring my old ones, They didn't have anything for a 50 model.
red49 #1077608 01/06/2015 2:28 AM
Rockauto has them, Gabriel and Monroe, for the '50 3100, instock, for $13-$15
red49 #1077626 01/06/2015 3:23 AM
O'Reilly shows them in Monroe, $21.99 for the rear, $23.99 for the front. They can usually have them next day, no shipping cost. Or, if you get to the store early enough, possibly even same day, depending on how far they are from the d/c and if they have them on hand.
Bill Burmeister
LONGBOX55 #1077928 01/07/2015 9:51 PM
Great, I will get me some ordered today, thanks guys
