0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 13 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 13 | I bought a later model 235 for my 1950 3100. The bell that is on it has different mounts than my truck. Is there any gotchas to swapping the bellhousings, other than disassembly/reassembly and checking runout?
I'm converting the truck to 12V and pushbutton start. My plan is to take the bell off the existing engine, remove the foot starter, and put it on the new engine. I plan to keep the clutch/flywheel from the new engine and use the 12V starter that is on it now. Any starter gear alignment issues that I will face using the old bell and the flywheel off the newer engine?
Thanks - Jim | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | Everything should work find. The only minor difference is the exhaust angles, gas pedal linkage location.others will let you know if I missed something. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | As you probably know, some of the bellhousing attaching bolts are behind the flywheel. Be careful unbolting/removing the flywheels; they're heavy and have a tendency to mangle fingers if you lose control of them as they turn loose from the crankshaft dowel pins! Jerry
| | | | | Joined: Aug 2013 Posts: 13 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 13 | Thanks guys. I will definitely wear thick gloves when handling the flywheel! As far as exhaust I'm having all new exhaust done so I don't have to worry about mating up to any existing stuff. And I'm putting a new Weber 32/36 from Langdon on so I'll deal with gas linkage with that. | | |
