1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1077081 01/03/2015 8:51 PM
Have a buddy working on a gmc and just discovered he has bent push rods.
FLAPS is closed today. Rock Auto doesn't list them. Are they difficult to source?
1951 3100
JW51 #1077101 01/04/2015 12:08 AM
1 Offline
Take your time and investigate the reason why the pushrods are bent. Most common problem is that the valve stems are rusted and not allowing them to move up and down. Penetrating oil and tapping the tip of the valve stem only and not the retainer may loosen them up. Check all of them.
Good luck
The older I get, I only want to work on older rigs.
JW51 #1077124 01/04/2015 1:31 AM
3B Offline
Hy JW51, you can straighten the bent pushrods, once there is nothing but spring pressure to stop the valves from moving they should be fine, hope that helps.
JW51 #1077186 01/04/2015 6:13 AM
Jim Carter lists them as the same for 235/261 and 248/270/302.
He found a set from a 216 that are supposedly 1/16 shorter than the gmc. Does that seem to make sense to anyone? Would assume those are incorrect?
1951 3100
