11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 25 Junior Member | | Junior Member Joined: Mar 2005 Posts: 25 | I was wondering did chevy use a black primer at one time. I have a 59 3/4 an the the paint code on the door is spc. I started to sanding an after a glossy black paint I hit metal. Any imfo. will be of great help.
annalei0
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not glossy for sure - you may have not noticed a flatish black OEM coating, or maybe someone has previously done a strip/repaint - my 58 had 6 different color coats [original owner musta had it repainted every few years!], and under the original white was a light brown primer sorta like the modern 'rust' primer color
Bill | | | | | Joined: Feb 2005 Posts: 3 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 3 | Speaking of 59 paints does anyone know what the paint code 732J is? Its on my 59 Fleetside. | | | | | Joined: Feb 2005 Posts: 3 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 3 | Speaking of 59 paints does anyone know what the paint code 732J is? Its on my 59 Fleetside. | | |
