7 members (66flea, Steveoreno, Jay R, Phak1, Joe H, 3B, Goach2),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,198 Posts1,057,270 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | What is the centered measurement between mounting holes. | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | While I an really appreciative of any answer I receive here on the bolt, I was on the phone trying to close a deal on a set of steel arm rests off a 53 Desoto, which seemed like they might work on my 52 Chevy truck, that is why I needed centered measurement on a pinch. Was not able to find the answer I was looking for in your reference. But when I got home I measured it and it looks real close at a 6" centered measurement and the Desoto was at 5 3/4. I really would like to have metal vs. plastic, so the search continues, thank you again, HUGH
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've read on another site
49 to 52 Plymouth and dodge car arm rest will fit and are metal
49 to 52 chevy delux car arm rest will fit and are metal
Info credit from post on other site. Deadzonetrucking. MotherTrucker
Good luck
The repos truck plastic arm rest I've purchased from classic parts have held up well for 4 years with not problems. They are actully made very well.
| | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | DADS50, Thanks for that information, guess I was off by a year as I had read somewhere to that these other models would work, thank you for your quick response, HUGH | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have no first hand knowledge the info will work , but the person who made the post is very knowledgable and I've purchased parts from him in the past.
A least it gives you something to look for to compare
The car armrest has a stainless trim | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | I believe I have a set of Buick arm rests that are an exact fit, all metal with the exception of the padding and cover. I'll take a picture if interested. I've had these on for several years and they are excellent. pic one, Buick arm rest pic 2, showing metal underside cover pic 3, topside, easy to recover but ok for now (ha ha, 4-5 years)
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Not exactly sure which direction I'm going to go on this matter. Thanks much for your quick response. | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Kevin
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And do you remember what year and or model Buick those were from Cosmo? dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | And do you remember what year and or model Buick those were from Cosmo? dg Sorry, no Denny I don't. I do remember searching 'arm rests' on eb@y for months armed with the on center measurement. If the 'oc' was not mentioned in the sellers info, I asked. My thinking was that General Motors wouldn't go too far outside the box during the 40's-50's for a simple add on like this and I would have success. As you can see from the pictures, there are three screws holding on that metal cover underneath and the two machine stovebolts securely fastened to the dedicated females in the door. Armrest without cover. Cover affixes to armrest with three screws. IMHO people generally under value the importance of a good arm rest/door pull. In the fall-winter when the window is up one pulls the door with the inside door opener which it is not really made to perform that task. In the months when a window is normally open the lower window sill can be used as a door pull leading to grime and wear of paint. After all, these are farm trucks in their souls and the aforementioned concerns were of little importance to the original owners.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the extra pictures, I'm gonna keep them in mind if I ever run across those in the bone yard. I've had a set of the repro's on my '50 for nearly 10 years and pull the door shut with them all the time. No problems yet, they are actually more solid than the ones on my '93 GMC. dg
