5 members (jmoore, klhansen, Charles in CA, Bill Hanlon, UtahYork), 67 guests, and 3 robots.
Topics128,179
Posts1,057,134
Members48,463
hoping to to do my fill work this week and just picked up a cheese grater.Do you let the filler harden or is this so you put on extra and shave it down before it cures? Thanks,Ron
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
You want the filler to set, but not harden. It should have a soft feel and not sticky. Here is a link from another stovebolter with a lot of good tips. http://www.autobodystore.com/bofb.htm
Good Luck with your project.
I
I Offline
to grate cheese!
Wocka wocka wocka!
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
Yes, overfill just a bit then use the grater as soon as you can after the filler starts getting stiff. If you wait till it's fully hard it'll be REAL tough.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Honestly, you leave it in your tool box unless you are filling some MONSTER dents with a LOT of filler.
I personally don't touch that tool but a time or two a year and I do this work every day for a living. It is for SEVERE plastic filler work. Anything that we usually would repair wavy panels, dents and dings you shouldn't even think of using a cheeze grader. It causes more work by digging into too deep. It "forces" you to apply too much filler, etc.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Sorry, but I've been taught different. The idea behind getting body filler straight so that you can't see any sign of it with glossy paint on it is that you have to cut the filler with very heavy grit sandpaper, or better yet, a cheese grater while it's still in plastic consistency. The cheese grater gives a rough finish, but it cuts so well and gets your panel straight. I've used it for under a quarter inch of hard-to-sand fiberglass impregnated bondo.
You will have a rough finished first coat of body filler, but then again, it is aligned with the rest of the metal panel. Then you go over it again and fill in the roughness. Hit it with 40 grit but don't take it quite all the way down. (You see, light sandpaper won't cut through the filler to shape it flat). Then take it down further with 80 grit and go to the metal again, like you did with the cheese grater. You'll have most of the roughness out of it.
You'll still see this if you stop here. So you want to get glazing putty (preferrably NOT lacquer based) and spread it on top. Then hit it with lighter sandpaper like 100 or 120 and feather-edge it.
Finally, spray some primer, let it dry, and you'll probably see if you did a good enough job or not. Then very lightly spray a different color primer over it...just dust it. Then block sand it and you'll see any low areas then.
With the modern primers, you can put filler over them, but at least scuff the surface first. Preferrably, filler sticks best without primer, but when detailing like this, sanding out the primer could cause more problems. The filler I'd use here would again be the glazing putty.
Then primer it again, and guide coat it again, until you get it imperceptible to sight or touch.
It is best if you keep your filler as thin as possible. So try to work your metal to where you can keep an 1/8th inch or so of filler at the most. You'd probably be okay with a quarter inch in places, but try to get your sheetmetal close.
This is an art, and it takes a lot of practice, so don't get discouraged.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
