| | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Found real nice rims at the flee market, Question is how do I tell if it's from a ford or chevy or what? Didn't buy them yet, will wate until this weekend.Could take off the wheel and trace but Back hurts and thought this would be easy to ask first. Both are 16" and the new onea are 2 different widths and they are only $50.oo.Can't beat that, just hope they would fit......Thanks, PS it's a 53 3600 with a 4 speed trans, old farm truck,and cool. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy red 53 pickup, does the seller know what the dimensions of the bolt pattern are, or what they are intended to fit? I know some bolt patterns have been changed to metric dimensions. Does your truck have the 14" rear drums? I don't think 16" wheels will fit over the 14" drums, hope that helps. | | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Better make 2 patterns to be sure. A little more work but it's $50.00..... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can you get pictures. Most late model wheels will not work on the older trucks due to the backspacing being too deep. Also, if they are '98 or newer Ford Truck wheels, those are metric and will not work. Ford Van wheels will be ok, though.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For years Ford 3/4T wheels would fit both Chevy and Ford but Chevy just fit Chevy. The center pilot hole was smaller on the Chevy.
Evan
