1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1076186 12/30/2014 6:33 PM
So I decided to rebuilt a 235 for mmy 42 suburban and have a few to choose from.one of the has the stamping 04 on all the Pistons is this a virgin block that has not been honed yet? Or did they stamp 40 over backwards as usual all info is very welcomed.
I'd clean up the top of the pistons for a better look at the markings. You can also measure the bore and that will tell you if the block has been bored.
I did and every single one has 04
What was the stock bore size does anyone know off hand?
1 Offline
3.562" is the stock bore size for a 235.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Ok.ill me sure when I get back. So does anyone know what 04 is?
1 Offline
It could mean .040" oversize. If so the bore would be approx. 3.600" in size.
Albert Einstein
Ok so what rings would I get standard? ,
Not if the bore is 0.040 over.
You, or someone, will have-to (want-to) measure the bore on every cylinder.
H Online: Content
A $20.00 set of dial calipers will be accurate enough to get a ballpark guesstimate of bore size. A set of telescoping gauges and/or an inside micrometer will be more accurate. Be sure to measure about 1/4" or more below the top of the block to avoid getting an incorrect measurement due to carbon buildup above the piston ring travel, or remove the carbon with a wire wheel in a drill motor before measuring. Also check the taper of the cylinder. If it's tapered much over .005" top to bottom, the block will need to be rebored.
Ok i will get back within a few days on the results. I'm stump on the marks.
