2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | I have what I believe is a stock transmission in my COE. My questions are, 1.Would a SM465(I have in the garage) give me a higher top speed? Or do they have the same top gear? 2.If so would the stick shift adapter and the reverse lock out shifter fit it off the original tranny? 3.Is that to much weight to hang off the back of the motor? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Straightjacket, I will answer your questions as simply as possible 1.No, both transmissions are 1 to 1 in high gear, direct drive. 2.No, those two transmissions are totally different from one another including dimensions. 3.No | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Thanks for the quick reply. Kinda thought as much. Funny how the extra parts in the shop are never the ones you need. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Got to talking with the owner of the local yard about this. He has a Brownie OD that he said would be more period correct than other options. I will have to search out some opinions/information on this. | | |
