| | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Will I be able to paint my steering wheel on my 60 Chevy? It is black now and would like to paint it white. What would the best paint to use??? | | | | | Joined: Aug 2004 Posts: 19 Junior Member | | Junior Member Joined: Aug 2004 Posts: 19 | Use PPG's epoxy primer then top with single stage paint. I use PPG's DCC.
You have to clean the wheel w/thinner & sand w/400 wet.
Don Meyer-PhD,mech engr
| | | | | Joined: Jan 2005 Posts: 34 Member | | Member Joined: Jan 2005 Posts: 34 | Yes, don's correct. What you may find though is years of skin oil in the wheel might make it tough to coat and cause fish-eyes in the paint. Start with a warm soap water solution and scrub it out real good. Follow that with alcohol, iso works just fine, denatured is good too. Then prep and paint like don said. If you want a 50's/60's looking translucent look to the white it's easy. Start with a white base with some gold or silver pearl mixed in, and add a few drops of gold candy or transparent tint to the clear-coat. Coat it sparingly until you like the look, then add 2 coats of straight clear over the top. Did a 54 Caddy that way and the owner thought it was an NOS wheel. But in general it's just plain kool. | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | This months "Vintage Truck" has a good article on steering wheel restoration.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Eastwood has a nice little book on the subject, too. | | |
