1 members (52Carl),
77
Mod | | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | 1951 3100 '05 LS 1 engine install need help on fuel tank source and advice on install etc. Just need to avoid any pit falls if I can. thanks for any info or links for install/source | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Checked tanksinc.com they seem to have the items my issue now is finding someone who has been down this road and will share some knowledge on doing this on a 3100 trk. My cross member I put in for the coil overs on the 4 link rear has left me with an opening of 14-15 inches. I need 17 3/4 in for the tank plus some room for attaching the tank. Does moving the rear cross member cause any major issues?? Any hot tips on line configuration or which regulators and pumps to use etc?? Would just like to avoid any mistakes from someone who has done this. Engine is LS1 5.3 from a 05 Tahoe stock non modified. Thanks for any help! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Don't know if this is helpful but I'll throw it out there...'99-'04 Corvettes(w/LS 1) use a pricey fuel filter with a built in regulator/return meaning only one line needs to be run to the engine.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thanks any info is more than I have now. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Vette crazy I think we may have talked before, but anyway I have the exact setup, ls-1 in my 51 3100. I used the stainless tank from tanks inc.. I did move the rear cross-member back. But before I did I had someone weld in a rear brace. Also on my bolt in 4link I had the shock mount welded in for a little extra support.I did not use the Vette filter like most others, it will save you on fuel line if you do. I ran braided line to and from my fuel rails. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Corvette filter regulator works great. I used one in my 96 Blazer 5.3 conversion and my 68 C20 conversion . Both with 2005 5.3 engines. I used a Boydes welding aluminum tank in the 68 with intank pump. On the Blazer just used stock tank and pump. Hard lines along frame with stainless braided connecting to tank and filter reg, and to the engine fuel rail. Put the filter regulator close to tank and have short run of return line. Good luck with yours. Jim | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | I had planned to use the Corvette part to save on running extra line if it would work OK. Just seemed a little simpler maybe.
Anyone got any available pics? Thks, Don | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | Thought I would throw it out here. If your looking for ideas? and you think about redundancy [cost vs/ hassle] here's one that can save a hassle: a trail rig set-up uses 2 in tank fuel pumps. if one goes out, switch a wire to the second pump and keep on going. 1 pic2 pic3 pic
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thought I would throw it out here. If your looking for ideas? and you think about redundancy [cost vs/ hassle] here's one that can save a hassle: a trail rig set-up uses 2 in tank fuel pumps. if one goes out, switch a wire to the second pump and keep on going. 1 pic2 pic3 picNever thought of that before-- | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Hi; I have a 53 Panel with LS1. I used a tank from Ric's Hotrods in the rear. Brackets on the tank are welded on so they much up with cross member of four link (welded on brackets). Slid the big cross member back and use it to mount the rear of the tank. My problem is now that there is little room for exhaust to go. The tank has the fuel pump and I have made a hole in the floor for getting at it. Hope that helps. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I ran my exhaust out of the side, before the rear tire. It has a small opening in the running board.that let's the exhaust exit. The tips are the same height as the running boards, makes it look neater. | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | I got a set up from tanks--got the mtg in at the rear where spare was. Putting side mtg spare on the trk. Haven't got the lines run just got to that point. As with many others I got side tracked on another issue that came up on another car. Hope to get back to this when weather warms up. Mother-in-law got hit at a stop light so got it to fix--list goes on and on--LOL | | |
