7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | After I paint my bed, after all the hours of bodywork, I'd like to keep it from being scratched/etc. I am going to be hauling motorcycles in the back though. I'm thinking of getting a plastic bedliner that will protect the sides, which I can take in/out. anyone have any other ideas? thanks
'53 Chevy truck 1/2 ton
| | | | | Joined: Aug 2001 Posts: 35 Member | | Member Joined: Aug 2001 Posts: 35 | Don't go with the plastic bed liner - it'll just scratch the heck out of the new paint and finish. Bikes don't put a lot of wear and tear on the bed - its the other junk you end up taking with you. I would just be careful and not worry about a liner.
If the bed is totally metal - not wood and metal strips, maybe spray some extra sealer over it so it is more resistant.
If this is a rod and not a classic - I'd recommend a sprayed in liner, like Rhinolinning - these can be color matched (to some extent) and work really well. | | | | | Joined: Jul 2001 Posts: 12 Member | | Member Joined: Jul 2001 Posts: 12 | I agree don't go with the plastic bed liner. Maybe a bed mat. Or do the opposite, glue carpet on the bottom of the old tool box, etc. Problem with a bed liner is they move around and you can't see the damage being done until you yank it out. They also trap moisture. Not a good thing!
There is no problem so great that it cannot be solved by the application of thought, elbow grease and copious amounts of CASH.
Snappy
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | A friend in town sprayed a Rhinoliner-like coating into the bed of his 5-window himself. I don't know how these hold up but it looked great. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | bedlines hold up great! only problem is I don't think there is a way to take the stuff off! :p I'm actually debating on doing the bedliner on my truck, but I haven't decided yet! | | | | | Joined: May 2001 Posts: 36 Member | | Member Joined: May 2001 Posts: 36 | The kickstands of the bikes will gouge the paint. Use a bunch of old socks to slip over the kickstands and have at least 3 fastening points to tie down the bike ( 4 is better), keeps it from jostling. Roll the bikes into the bed and onto a scrap piece of clean carpet, fuzzy side down. In a pinch use floor mats. Magnetic pan for oil drips is cool. Most everything else will hide the new paint or scratch it up. Old custom "rodders' of the mid-1950's used to put a white tonnue cover (tarp with snaps) over the bed to add a second color to the trucks' scheem and protect the bed paint. The heavier the bike the more it will try and gouge into the bed. john | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Rubber mats are available for most any truck. It can be rolled up tight and stored behind the seat if you want to show off the bed. Also, maybe one the carpet liner companies has a mat type product available. 'Course if you bikes are AMF era Harleys,the you'll never get the oil out of the carpet! | | | | | Joined: Aug 2000 Posts: 14 Member | | Member Joined: Aug 2000 Posts: 14 | Just toss a piece of plywood in the bed when you're hauling bikes. The plywood will set up on top of the skid strips and protect the bed wood (unless you've recessed the skid strips, defeating their purpose).
To protect the bed sides from bikes, fabricate wooden rails that drop into your stake pockets and are offset about six inches inside the bed to keep the bikes off the bed sides. This is a cheap solution you can knock together in a hour or so, it's easy to remove, easy to put in, and stores in a lot less space than a bed liner.
Since the whole idea here is to protect your paint job, attach cotton rope around the edge of the plywood where it comes in contact with the bed sides, and between the wooden rails and the tops of your bed sides.
Barrett Revis '53 3105 '48 3105 The fewer the moving parts, the less there is to go wrong... | | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | Thanks everyone for your ideas, I think I'm going to make some kind of carpet mat for the bottom, i'll get some marine grade carpet. (And an extra 'flap' to roll out over the tailgate  The idea of using the stake pockets is great, i'll use that for both sides. The bikes i'm going to be hauling are actually dirt bikes...
