7 members (mick53, Shaffer's1950, klhansen, TooMany2count, Peggy M, Hotrod Lincoln, 1 invisible), 83 guests, and 2 robots.
Topics128,132
Posts1,056,388
Members48,441
#1075591 12/27/2014 4:52 AM
We're going to clean up some wiring in the engine compartment. I like to run my own wire.
Where are you guys getting your bulk wire? I hate the cheap wires available at the local stores.
I bought fabric coated wire in bulk/ by the pound at this surplus location. They have everything, all you have to do is find it!
http://www.apexelectronic.com
Good luck!
Wow, that place looks crazy. Probably a lot easier if you can dig through their inventory.
If you want modern wire then this is the only thing I use. SXL; thick walled, special purpose automotive wire insulated with cross-link polyethylene. It is resistance to moisture and most solvents. Operates at -49 to 257degrees F. Meets or exceeds a bunch of S.A.E. Specifications.
I get it in bulk from www.delcity.net. I also buy their flame retardant slit loom. I have melted the cheapo loom bought at swap meets.
The only thing I want to go up into smoke on my car is the rear tires.
