8 members (Gdads51, Peggy M, Wheelie, Bill Hanlon, SWEET, TUTS 59, Phak1, 1955 1 Series),
93
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 21 | Has anyone done an inexpensive lowering job on a 3600 chassis? I have bought an air ride kit to adapt to my truck but was wondering if one could flip the front springs or remove a few to get the stance I want. I don't want to hack the frame up but trying to keep it close to stock as possible with the 216 engine and drive line. I love the truck but not the height! | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Try 2 yards of gravel in the bed- - - -that's the way they got lowered back when they worked for a living! Jerry
| | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | how low are you planning on going? I dropped my '51 3100 4 inches and then removed some leaves in the front. 3" drop with spring removal in back. I am unsure if you are able to do this or not since I don't know about your truck and the differences. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | These old trucks ride poorly when everything is right. If you lower it, I am sure that it will only make the ride worse and likely less safe. But then I am very partial to the look of the original stance even if heavily modified. To each his own.
| | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Carl, I am slowly working towards making my truck a "HotRod" like they would have done it back in the 50s. I am not currently looking for an LS3 and camaro (mustang) front end or anything. It is all about having fun with your build right? | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Carl, I am slowly working towards making my truck a "HotRod" like they would have done it back in the 50s. I am not currently looking for an LS3 and camaro (mustang) front end or anything. It is all about having fun with your build right? Absolutely! I was actually being sincere when I said 'to each his own.' Carl
| | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 |
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Sid at dropped Axles is GREAT! He worked with me and i feel like I got a great product! | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | Sid's axles are the way to go in the front. When it comes to the rear on the 3600's you haven't got much distance you can drop before your having to install a c-notch in the frame for axle tube clearance. I myself like the "hotrod" stance of more rake between front and back. I use Sid's axle (4" drop) up front, and removed all overloads as well as 2 or 3 leaves from both back spring packs (no c-notch). Not a ground scraper by any means. But hopefully a nice usable everyday driver/puller style truck.
By the way, I did switch to 1/2 ton running gear.
Tim
