6 members (walter74, Hotrod Lincoln, mason86, 55shaker, Otto Skorzeny, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,684
#1074660 12/22/2014 12:58 AM
I tried this a couple of times in the Engine Forum with no luck, so trying it here. Does anyone know where to get a heat riser spring for a 66 292, 65 and earlier are not the same. I have tried everything that I can think of, with no luck. Any help would be very much appreciated. Thank you.
Try Tom Myer, this guy seems to have everything.
Tom Myers Truck Parts
54460 East 110 Road
Miami, OK 74354
(918) 542-3871
You should be able to get away without using the heat riser...I had no issues with mine. If you can find any 230-250-292 engine at a junk yard you probably could find one there.
1964 C20 LWB 292 6 cyl/sm420 parts truck.
1966 C10 SWB 292 hotrod 6/TKO600 tremec 5 speed.
1964 GMC 1500 LWB 305E V6/ SM420 "Crustine"
1977 C20 LWB 496/turbo400(soon to be 572)
My youtube channel: https://www.youtube.com/channel/UC_hdwhPFzfzpcUXyK_5-uiw
