1 members (Shade Baby),
58
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I tried this a couple of times in the Engine Forum with no luck, so trying it here. Does anyone know where to get a heat riser spring for a 66 292, 65 and earlier are not the same. I have tried everything that I can think of, with no luck. Any help would be very much appreciated. Thank you. | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | Try Tom Myer, this guy seems to have everything.
Tom Myers Truck Parts 54460 East 110 Road Miami, OK 74354 (918) 542-3871 | | | | | Joined: Dec 2014 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 72 | You should be able to get away without using the heat riser...I had no issues with mine. If you can find any 230-250-292 engine at a junk yard you probably could find one there. | | |
