7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | I'm hooking up the 6 volt generator and need help identifying the capacitor looking thing.
It's screwed into the case and has a lead to connect it to one of the therminals. I have a post marked "F", the other is unmarked.
Anyone know which post to attach it?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F = Field terminal It is most likely a radio noise-suppression condenser (figure 57). | | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Excellent, thanks for the intel | | | | | Joined: Feb 2004 Posts: 29,768 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,768 | DO NOT attach a condenser to the field circuit. Unless you're running an original-equipment AM radio, the condenser on the Arm. terminal is not required. It was there to filter out RF frequencies created by the commutator bars of the armature. Jerry
| | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | No radio in the 3600. I'll remove the condenser. | | |
